I have some radial shaft play on my turbo. I believe the oil seals are blown because i get a good amount of blue smoke. It only smokes after I push it then put the clutch in and let it idle, blue smoke will pour out for a bit. There is a lot of oil in the intercooler pipes so im thinking it's pushing oil through into the engine. also no smoke on startup..
What do you guys think?
