power steering?!
So one day my pwr steering went out, i located pump and noticed no belt on it, so i took off all the other belts to get to that belt put it on oblivious to the tension it needed to be at, everything worked great...happened again few months down the line, i then researched it a lil better and found correct tension... everything worked great.... earlier i was looking around in there and saw that the belt is really messed up already, coming apart at the sides.... could this be a crooked pulley or what, basically i was wondering if this happened to anyone else or if they knew some good checks to do, to check that area, any info helps, thanks.
