Thread: starting motor
Old 04-04-2007, 01:52 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Dom
been having trouble starting car past few days just getting a click click noise when turning key sounds like solanoid ( i think ) but today it sounded like the starting motor kept running after car started and when i turn car off and took out keys the car kept turning over , so took starting motor out theres two copper brushes under a steal plate cover these are very worn ,can i buy these on their own ?i think that was cause of car not starting but why do you think it kept turning over when i took keys out ? ignition problem? any opinions
I know that Toyota sells a starter rebuild kit, and I believe it includes a new set of brushes. In addition, I'm pretty sure that the kit is very affordable.
Regarding the continual-cranking problem, there's a separate circuit that triggers the starter. To be honest, I've never heard of this exact problem before on an Mkiv Supra TT, but I believe the TSRM has a set of diagnostic steps to troubleshoot this symptom.
Of course, I'd also welcome the input of any other forum member that has experience with this type of issue...
Life begins at 30psi.
