code 14 and 52
well hi again everyone, as the subject says i got a code 14 "ignition and ignition coil circute/ignitor and ignition coil/ECU" and code 52 "knock sensor"
could the 14 be setting it off the code 52, say in the case that the coil wasnt working properly and causeing the engine to knock <creating the 52?!?!? if this is the case i have another coil pack
7MGTE - 500hp  never dyno'd
fidenza cam gears
