The universal fuel rail won't work. Use the stock rail and drill and tap it for -08 supply and -06 return. A friend of mine just put down 814rwhp using a stock rail with a single -08 feed line. If you want to run dual feeds use -06. You may need to relocate the alternator to run dual feeds.
Nate
