Originally Posted by kwnate
You may need to relocate the alternator to run dual feeds.
oh comeon its not like you need the alternator  when you say drill and tap, where the main lines hook up or the internal of the housing?
7MGTE - 500hp  never dyno'd
fidenza cam gears
