Originally Posted by mrnickleye
Does the engine run good?
MMM kinda until the damn light comes on
Does it run good on the test drive??
UH like i said above
Any stumbling or misfires??
it does stumble it drags as if i just lost 100hp ill floor it and the turbo spools the motor makes the wwwaaahhhh noise but it dont the body just dont move very fast. like a spark plug isnt going or like talked about in a previous thread injectors. but if its the coil pack not working properly that would make just as much sense.
Hows the idle??
that is a random good/bad. sometimes its good and will idle 600-1000rpms but when i run it hard or rev the motor high it will drop to about 200rpms almost die and then recover itself to about 400-600.
im really getting tired of this issue.
oh and one last thing, i have noticed that the cam gears arent at the same possition. one of them is 1 tooth off. should i fix this and how?
7MGTE - 500hp  never dyno'd
fidenza cam gears
