Old 04-07-2007, 02:44 PM   #152
yama1
yama1 is on a distinguished road
Default crank pulley removal
Dude, I had the same problem
No help really with tool support. The impacts don't work.
I ended up pulling the starter and wedging one of my long pry bars in the teeth to hold the crank. Granted I had the motor out at the time so it was easier.
Just use a 1/2" 19mm with a long bar and it will break loose pretty easily. The flywheel is much larger, so the torque on the tooth is not a real issue, but be sure you have good surface contact and not a point load.
Hope this helps out.
No need for the SST, Waste of money.
yama1 is offline   Reply With Quote
