Old 04-08-2007, 09:16 PM   #2
supramacist
supramacist's Avatar
I wouldn't think it wise to mix and match cam gears but to answer the first question..., yes they should fit. If there is any change to the gte cam it will be inside. I wouldn't put ge cams in a gte engine either. I am quite sure they lope differently.
I would put some thinking and research into this plan as to make sure I didn't mess something up. No gains to be had using the smaller cams, they'll work untill you set off a sensor somewhere, vapor lock for lack of a better term.
