Thread: code 14 and 52
Old 04-09-2007, 05:34 PM   #11
IHateHacks
IHateHacks's Avatar
No, first install that timing belt the way it should be. Then, set base ignition timing. After you do these 2 things you will be able to diagnose your problem further.
Instead of throwing parts at your car you should have tested your coils with a multimeter.
