Old 06-02-2005, 10:20 PM   #19
eandris
eandris is on a distinguished road
Originally posted by KingDiamond@Jun 2 2005, 08:45 PM
I've used prestone sealer plenty of times, works nicely, and may i suggest for a bhg , you use the prestone sealer for big leaks.
Should I remove the thermostat when adding the block seal? Just put it back in last night thinking my problems was solved. :angry: Also, the directions says not to run the car at high speeds (freeway) with sealant in it while I've heard others say to run it in order to seal all the leaks. It seems to make much more sense to run it for a while to have the sealant run through the whole system.
Thanks again for your response
eandris is offline   Reply With Quote
