Does it sputter when you go past 2500
Can only depress the pedal at a certain point b4 it chokes and dies?
Can the car still move until you past a certain throttle point?
If you answered yes to all the questions
You might have the same problem that I had
There was a wire on the afm which got cut
So my suggestion is check all of your wires and check the afm plug if it properly secured
Let us know what happens
