That's what a lapping tool does. Its a heavy (like 60lbs) disc about 12 inches in diameter. You use a special lapping compound that acts as an abrasive. You can do this with the block in the car, but it WILL kill your back. And like I said you need to find a way to remove the dowel pins from the block because they will interfere with the lapping tool.
