ok well it seems the dowel pins r ganna be the problem, and if u can just wet sand it or use rubbing compound or sumthign to smooth it out y not just do that, i dont think u necceserily need a lapping too. u culd essentially use a disk sander with high grit and sum kind of rubbing compound, im almost 100% sure there ways around this...all i gatta do is take those pins out then.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
