Where was this engine sitting prior to you taking it apart? It looks like water filled up a couple of the cylinders. Those rusty cylinder walls do not look good.
What did you use to clean the pistons? I used a whiz wheel on mine but I couldn't get in all the grooves on the pistons. Yours look brand new. But I also used it on the block surface and it took all the old gasket material off and polished it up really good.
