Old 04-11-2007, 05:04 PM   #5
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Thumbs up body talk
i think they were talking about undercoating b/c when i weld a patch in where rust was or if i fix a Q pannel then i always use undercoating also known as rubberizer. its cheap stuff prolly 5$ a can all i can think of is that your car is worst off than you can see. but i would go 2 about 2 more shops and get an estimate. w/o telling them the first quote. see where it gets you
Supra_87_mk3 is offline   Reply With Quote
