so the items i should probably get for the cleaning process
castrol super stuff
pb blaster
dremel pencil shaver
and high grit paper
oh and a new wire brush because the one im useing is almost finished with.
and what is TDC?
7MGTE - 500hp  never dyno'd
fidenza cam gears
