crank shaft pulley puller
Do I need one of these tools to remove the crank shaft pulleys so I can remove the lower drive belt casing???
I jacked this thing up and the casing is built around the crank. I can get a 21mm 3/4 drive on it but I can't bust that nut and hold the pulleys at the same time and get anywhere, anyway.
Any ideas would be greatly appreciated.
