Old 04-13-2007, 01:33 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by randychunn
i would like to go to a with a dyno,but the problem im in mississippi and 300+ miles from any repitable specialist,could someone guide or send me a map if they have a simular set up,thanks in advance,i will hold noone responsible for any damage
Randy C.
my car is an auto
i have a map but it has a dead spot around 2k
sp63
stock cams
3 row fmic
4000 stall
4in custom exhaust
Have you tried the PHR or MAP ECU (Australia) websites?
Did you purchase your MAP ECU brand-new? If so, the vendor you purchased it from should be able to supply you with a better map.
Lastly, do you have any way to determine your air-fuel ratio at that 2k dead spot (eg. Wideband O2/Data logging)?
Life begins at 30psi.
