Originally posted by mrnickleye@Jun 3 2005, 01:21 AM
Stop by a repair shop and have them do a block test on the cooling system. They put some special blue chemical into their glass tester bottle, then they remove some coolant from the radiator, put the test bottle over the open radiator cap hole and run the engine for a few minutes, sucking in the air thats there. If the blue liquid turns yellow or green, you have a blown head gasket (very common on these motors), or a cracked head.
Me???first hand experience on mine!!! I also am an ASE Master technician.
:P good for you if you were a "ASE Master technician." n me i am a ASE Master that came out from the garage. but it work the same. as you are to. hehe. :lol:
