thank you
i really appreciate your help with my gasket and i am looking forword to building my car next sat... if i get the gasket in.. i dont know if i should go MHG b/c im not doing alot of boost prolly 15 pounds max until i tune it more.. im still mostly sotck until i fix the HG. Agree Or Dissagree Any Comments would help.
(turbo XS BOV. Intake, cat Back, front strut mount and coil overs.) looking for a boost controler and turbo timer.i would also like to eventualy get a stand alone system but im on a budget as of right now.
Reason: List of mod parts
