Originally Posted by IHateHacks
Just tried using a 1/2" IR titanium series impact and it still won't come off. This has got to be a joke. Tomarrow morning I'm using a 120psi (instead of 90psi) 750 ft/lbs rated impact gun. All of the other guns were rated up to 90psi max. If that doesn't work I'll have to bite the bullet and buy the SST's. I wasted too much time and effort trying to save a few bucks.
Except for the starter method, how does everyone else loosen their crank bolt?
And don't gimme the put in gear ebrake on stand on the brakes either because yea that doesn't work at all. Crank still spins.
your gana have to
1 do the put in gear method * but use a impact wrench so it use's more pressure than ur ratchit
2 lock up the motor somehow with the starter
