Thread: car wont start
Old 04-17-2007, 04:20 AM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Cool basic help
ok so i'm taking a shot in the dark and guessing that you have checked your starter already.. if this is the case make sure the wires on the body of it are hooked up ther is a small pigtail that can come loose easy on the mk3's mine came loose when i raced a probe gt (pile) i still won w/ my car stalled halfway down the road.(anyways) the next step is i need more info. does it turn over or does it just click? does it feel like it needs fuel? you said you just got it running how long was it sitting? what was wrong. what did you do to fix it... All of this is pertanent to the conclusion... Ps i really can't spell...lol
Supra_87_mk3 is offline   Reply With Quote
