Old 04-17-2007, 08:57 AM   #1
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Yeah it's not so bad. Just find a way to mark the mounting holes exactly. What I did was put some clay on the points on the wing that get bolted down or need a hole to fit into...then laid it on my car just as if it were already mounted. Then I took a sharpie and marked the points that had clay marks and drilled em out. The hard part was the center wing because that has to sit perfectly in the center or else you'll get some rubbing action done to one of the side pieces. You will need to drill out the bottom of the hatch so that you can bolt the two side points of the center wing. Go to a Home Depot or Osh and get yourself a circle drill bit to cut big holes with. After all this hard work you'll really like the look of the wing on any year MKIII.
Drag0na5h is offline   Reply With Quote
