this could acually be the end to this thread, mmm i took a closer inspection and the wires that hook to the coil packs at the bottom, i took all of the old electrical tape off and found that 2 wires where either melted or chopped a little and where barley hanging on, so i fixed it drove it and no CEL drove fine so im now going to see about getting a new fuel filter and get the timeing done.
now for a quick question on the thermostat houseing there are 3 connectors on it, the one with the 2 little hoses comeing off of it, a green thing with a wire comeing off it of, and at the bottom there is a blue one with a wire.
what is the blue one? cold start?
7MGTE - 500hp  never dyno'd
fidenza cam gears
