HP Upgrade time
hey, i have a 89 7mgte and a blown head gasket, so i just bought a HG off of HPF.com and it should be comming any day, its really thick like 1.71mm so compression will be down to 8-1 wich will be good. my next prob is when im doing the head job i think i should install a boost controller but i dont know what kind to go w/.what psi should ARP studs be added i'm only planning 15 to start prolly 20 MAX.(this 15-20psi is after i make sure everything is alright and working good) i just know the arp stud install is a hastle and i would like to avoid but if it is needed its needed, b/c the 7M head job isn't fun eather.
