Originally Posted by Supra_87_mk3
i feel like it can handle the 15psi b/c i have changed ever aspect of the cooling system, and got a BOV (no real help but looks cool ![Smile](images/smilies/smile.gif) ) intake, cat back.strut bar coil overs, and like i said soon MBC and turbo timer. anything else to do b4 i do this?
lol wow. Anyways, first off, what kind of hg did u buy. Second you need ALOT more gaskets than just the hg. Third arps are easy to install and technically if your doing the hg you shouldnt re-use the stock head bolts. There likely to stretch and result in another falure. So buy the arp's anyway. Fourth, if ur hg is 1.7mm thick, its most likely a metal hg, so you WILL need to send your block and head out for deck'ing. Fifth, dont go with a mbc get a electronic bc. Greddy profec's are cheap and even spec 2 profecs arent that expensive. All of this info could have been found in ihatehack's bhg install thread. I recommend finding it and studying it. This job is pretty staight forward if you know what your doing and you do your research.
