hmm that seems like alot of work just to set it up for drifting. i agree with everyone else, i dont think its worth the amount of money and work involved. your better off just stickin with the 7mgte or swapping it with a 1jz/2jz, with the 7mgte you will have to keep up on oil, check it before you drift it. the oil tends to slosh around in there. but just get yourself some good coil overs, strut bars, and a cheap set of tires or maby some good drift tires if your willing to spend. and you can drift that supra like there is no tomorrow. hell i drift mine everyday. and its almost completly stock. its not that hard of a car to drift you just goto get the feel for it, learn how heavy it is, have a feel for when you need to give it more gas. just go drift in a big empty parking lot in the middle of no where and do perfect donuts and figure 8's you'll get it down. if you lived closer id teach you how to do it
7MGTE - 500hp never dyno'd
fidenza cam gears
