Originally Posted by dcrusupra
Well, you can only drift with a RWD car. But I'm sure already knew that. The only way I can think of doing it is taking a 3s-gte from an MR-2 and mating a supra transmission to it and making custom tranny and engine mounts, and a custom driveshaft.
and dcrusupra told you how to do it.
7MGTE - 500hp never dyno'd
fidenza cam gears
