Thread: code 14 and 52
Old 04-20-2007, 12:26 PM   #23
IHateHacks
IHateHacks's Avatar
Timing guns are $39.99 at autozone.
If your valve timing is off, (you said one cam was a tooth off) it will cause missing and very poor drivablity.
Stop throwing parts at your car and fix what you already know (You said it!) is wrong. Fix the valve timing then set ignition timing, then you can further diagnose your problem if necessary.
