suspension problem
i just put some eibachs on my car with the stock struts(for now) and as i figured, they blew. im going to buy the tokico blues(i dont have TEMS). are they ok. this isn't my problem though. after i lower the car and had it aligned, they couldn't get the front passenger cam bolts to break loose. this was ok bc it wasn't off very much. that day i noticed a clunking noise from the struts(i assume its from the more stress being put on the stock struts). also i hear a popping noise from the front. it only does this when i turn the wheel all the way to the left or right and move(does it all the time) or when im coming to a stop with my wheels turned(doesnt do it all time). the guy who aligned it said it could be the cam bolts bc it could have broken loose the rust and now moving back and forth. what do you guys think? is it the ball joints?
