That's the beauty of the edfc
You can set it up to 3 diffrent dampening levels
And you have the luxury of setting inside your rather than getting out and setting it on top of the suspension,
Or worst sum suspension have the knob at the bottom which means you have to take out the tire to change the dampening
But your ride will on ur choice
If you want a smoother ride then jus change the dampening and you will be good
Trust me on this one
The tein flexes with the edfc is one of best suspensions that you can buy in the market right now
Every 10 second car I know has tein suspension
