Originally Posted by D_Train
Instead of going and buying coolant, can I just put water in with my coolant?
I wouldnt think it would hurt anything i have a mixed coolant right now mainly water right now cause i leak coolant and dont want to spend the money for more every 3 weeks... but i wouldnt run water if it is cold were your at could cause the block to crack or crack the radiator if it should freeze, and if your not leaking coolant just go out and buy some antifreeze that is what i would suggest.
