check inflation, wear marks, look at the tires for any bulges like a hudge zit. sometimes there small. and also push down on the car set your tems for normal and push it down, if it bounces more than 2 1/2 to 3 times you should look into getting new shocks. otherwise a good balnceing or alignment, if your really unlucky its the joints.
7MGTE - 500hp  never dyno'd
fidenza cam gears
