Thread: question
Old 04-25-2007, 01:38 PM   #2
j3pz
as long as they are both lhd/rhd you should be able to switch it over. also you will need a turbo gauge cluster as the turbo model has a boost gauge and the na has a voltameter. id also check to make sure its got the ecu will the dash is ripped apart, it under the dash, behind the glove box
