a pain
if you do this job then keep in mine this is no V8 you need to document everything put every nut and bolt in a bag and label it alsotake pictures of vacuum and mark w/ diff colors of paint where they go. b/c it is really easy to forget where one goes. and i have yet to see a diagram that is easy to read compaired to the location's of the lines.also remember where lines where ran. (like the vacuum hose ran up through the intake manifold from the bottom b/c if that line isn't up there you have to pull the manifold back apart to get it where you need.. Unless there is another way i dont know about) good luck if you get lost just ask
