well first check your brake fluid, and then i would get a friend or something to keep pressing on the brakes as you look under the car to see if you notice any leaks. No leaks, then you might want to take apart the front brakes and see if anything is hanging up, nothing you can find then go to the back brakes, still nothing wrong then i would probably say your master cylinder is probably shot, ot maybe brake booster.
