Old 04-27-2007, 07:04 AM   #26
mrnickleye
mrnickleye's Avatar
My experience, and more so, my research, has indicated that they both have good effects on raising the 'boiling point'.
Each pound of cap pressure raises the boiling point 3.25-degrees X cap pressure. So, if you're running a 15-lb. cap, then you've effectively raised the boiling point of your system 48.75-degrees or up to 260.75-degrees.
http://www.innerauto.com/Automotive_..._Pressure_Cap/
http://www.ferret.com.au/articles/66/0c044c66.asp
http://autorepair.about.com/cs/cooli.../aa081101a.htm
And all you never really wanted to know:
http://www.jcna.com/library/tech/tech0011.html
