uhhhhhhhhhhhhhh.
i have no clue what your talking about. what are these reading lights. ohhh you mean the dome lights. mmm does your targa leak? if you have one. well thats probably the reason why they are on fuses, water gets in it causes a short and then next thing you know your spending lots of mula just to rewire everything  but other than that i have no clue the only points of entry i can think of is the targa,front window, and doubt it but maby just possibly the drivers and passenger side windows. i guess you could always pull the covers off of the dome lights and look and see if there is any little rivers going on or little gaps that it could have passed through.
7MGTE - 500hp  never dyno'd
fidenza cam gears
