oh jeese, ok when your motor is apart there are 2 sections, the block <that has the pistons on it, then the head is the top half, i acually ment to say lifters, springs and valves, maby even new buttons, now port and polish
ill just give you a link for a clean description
p&p
7MGTE - 500hp  never dyno'd
fidenza cam gears
