Old 05-01-2007, 02:39 PM   #2
mrnickleye
mrnickleye's Avatar
Talking
OH....
If it were mine.....
I would attempt to bleed it out first.
If that failed to repair it, I would try to SEE into the pressure plate, throw out bearing area to determine if the arm and such all looked normal.
If so, then I would likely replace the master cyl. with a reman unit from Carquest. Cost between $65-$130.
Rebuild kits are $22-$42. If you KNOW how.
Slaves cost $18-$64. Kits $10-$18
