Old 05-02-2007, 01:26 AM   #23
IHateHacks
IHateHacks's Avatar
If you use studs, the last 4 (2 on each side) closest to the firewall have to be installed after the head is on. No big deal.
Unless you are planning on running more than 14psi with a bigger turbo, ARP bolts will be fine.
