Hey. I just installed a Turbo kit onto my 1995 Toyota Supra N/A. I am haveing a few problems with it and was wodering if anyone knows why.
Turbo Setup::
T04E Borg Warner Turbo
Custom Manifold
HKS BOV and 50mm Wastegate
Complete custom 2.5" Intercoolerpipeing
Front mount Intercooler
S-AFC II
K&N Filter
THE Problem::
Turbo spools up and boost fine. Car runs great and hauls ass. Dyno showed roughly 300hp. The problem comes if you run the car then push in the clutch, if you leave it pushed in the rpms will drop and the car will die. Also if you stop at a light the rpms will drop and die. You can save it by touching the gas and reving it up. The car works good and runs good but thies problem makes it unbareable. Any suggestions???
