When the lite comes on, and especially if you have driving problems, you should NOT drive far or often, as a possible cheap fix may cause more expensive damage. Where are you at? In smog cert required states and countries, the smog repair shops can easily diagnose the code set in the computer.
A coolant temp sensor is easy to replace, and cheap enough at a parts house.
