Alright I'm stopping engine production. Too many things aren't in place as they should be. Along with the afore stated Q's.
I have noticed that I have no nuts on the bolts that hold the starter in. I have the lower plenum and it's hose on correctly. I am missing some bolts that hold the exhaust pipe to the body right underneath where you reach up from underneath to tighten those bolts.
The coolant system unit that houses the thermostat.., I have no bottom bolt that will fit it. I have the top bolt and the nut. How the heck do you lose 1 bolt???. Too many hands taking things off at once that's how.
I'll move on to a different section of the auto until I get this sorted out.
My dead line is june 8th wich is my birthday. I don't know if it's going to happen that way it still has a trip to the upholsterer and from there it goes to my mechanic to give it the once over. And do some things I am not experienced enough to do.
Looking at the plenum is no help I can find everything that attaches to it..., it would seem
