I agree with kwnate, your trap speeds are far too low to be running 11's, that is, unless you slammed on the brakes at the end.
I think its just a typographical error on the timeslip, there really is no way you can be running 11's with just an open downpipe, 12psi of boost and a clutch on a stock 7M.
The first run is spot on though with a stock MK3, they run high 14's stock.
