hey maby you guys are right, maby i didnt run a 11. maby i did. im just telling you what my slip says. it may be wrong i don't know, but i thought i would just tell you guys, the point is i had fun and at the same time took every car i ran. so if it will make you happy my car if i was just lucky and somehow pulled a 11 out of my ass, it is running 13.5-14sec's on 1/4 @ 95-100mph, i wasn't planing on making war out of some simple numbers. but thanks for all of you who complimented me.
7MGTE - 500hp  never dyno'd
fidenza cam gears
