here is a mod list
Engine
BL71mm GTS 0.81 A/R Single Turbo
SUS321 Tig Welded Tubular Header
HKS 50mm SS Wastegate
4” Stainless Steel Downpipe
4” Stainless Steel Midpipe
4” Aluminum Intake Pipe with Anti-Heat Coating
4" Boost Logic Polished Exhaust
4" AEM Dry Flow Air Filter
PHR Stage 2 Complete Fuel System
PHR 17.5mm ID high flow fuel rail upgrade
-6AN Stainless Steel braided fuel lines
liquid-filled fuel pressure gauge
Siemens 850cc fuel injectors
Dual Walbro fuel pumps
Aeromotive EFI fuel pressure regulator)
HKS 264 Cams
Crower Springs and Retainers
Boost Logic Crank Pulley
HKS Racing Blow-Off Valve Type 2
Titan Motorsports Cam Gears
Greddy 3-Row FMIC
ARP Head Studs
Powerhouse Racing Polished Upper Radiator Pipe Kit(Red Silicone)
NGK Model 3330 Spark Plugs
Transmission
V160 6speed Getrag
RPS Stage 3 with 6-puck Sprung Hub Disc
Fidanza Flywheel
Electronics
AEM EMS(Engine Management System)
AEM Map Sensor - 3.5 bar
HKS DLI-2 Twin Power Ignition Amplifier
HKS EVC 5 - KPA Measurement (Electronic Boostcontroller)
PLX Devices R-500 Wide Band Kit
Blitz Dual turbotimer
AutoMeter 52mm Boost Gauge
Chassis
18" Antera Wheels
Lowering Springs
Cusco front and Rear Strut Bars
Toyota Supra TT ?96  BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
