shimming the wastegate will add more boost levels, like mine boost gauge is pegged out right now, im doing about 10-11psi on the stock turbo, but if you plan on shimming the wastegate its not recommended to go about 4 washers, although just putting 4 on was a pain in the ass.
7MGTE - 500hp  never dyno'd
fidenza cam gears
