Old 05-12-2007, 04:46 AM   #12
Number_Sixx
Number_Sixx's Avatar
Number_Sixx is on a distinguished road
ok.......so you changed the synchros already so I am guessing you don't have an issue with gear changing. Now as for the popping sound when you try to move off.......the only thing I can think of is that one of the plates on the hub is cracked.......I am referring to the racing clutch. Yes they can break, I have seen that happened many times. People put racing clutches in street cars and have catastrophic results. But that is one area you can check out if the problem still persists. Can you post some pics of your Supra donovan??
Number_Sixx is offline   Reply With Quote
